issue with reference_correction and epitch/eyaw misalignments
Post Reply
GPenn
Post by GPenn » 27 Aug 2021, 12:23
Hi,
I'm seeing a large discrepancy between tracking with and without REFERENCE_CORRECTION in CSBEND elements, when there is also an epitch or eyaw misalignment. The case with REFERENCE_CORRECTION=0 seems like a closer fit to AT calculations, and the final offset is much smaller which seems more reasonable. For a typical bend magnet with epitch=1e-5, there is about a 1 micron difference in final position of the particle (starting on axis). This is with elegant 2021.2.0.
A minimal set of example files is attached. The same size discrepancy appears if I set eyaw instead of epitch, and it also doesn't matter if I use malign_method = 1 or 2. If there is just an etilt, then the difference in tracking results is much smaller.
Thanks,
Gregg
csbend.ele
run file, with and without reference_correction
(583 Bytes) Downloaded 6159 times
csbend.lte
lattice file
(746 Bytes) Downloaded 6155 times
Contact:
Re: issue with reference_correction and epitch/eyaw misalignments
Post by michael_borland » 07 Sep 2021, 01:20
Gregg,
Thanks for reporting the bug. The attached file should fix it.
csbend.c
(210.89 KiB) Downloaded 6087 times
GPenn
Post by GPenn » 07 Sep 2021, 21:58
Thank you, that did the trick!
-Gregg
Post Reply
