Dear Michael,
I think there is a bug in the correction_matrix_output command then BEND.FSE is used as steering element. Closed_orbit command gives a different result.
Please take a look at this example script.
I would like to use BEND.FSE in a response matrix fitting. Is it supposed to be used that way? We have a horizontal correction as additional coil in 45-degree dipoles.
Thanks,
Alexey.
Orbit response matrix for BEND.FSE
- Attachments
- hrm.png (10.4 KiB) Viewed 10208 times
- PAR.tar.gz
- (23.24 KiB) Downloaded 1128 times
- Contact:
Re: Orbit response matrix for BEND.FSE
Alexey,
This is an interesting result. I think the problem is that for orbit response matrix computation, elegant assumes that the kick delivered by the element occurs at the end of the element. This isn't exactly right, but is usually "good enough."
I'll have to think about how to solve this. There isn't a quick fix or workaround that occurs to me.
The only thing I can suggest for now is to compute the response matrix outside of elegant based on difference orbits.
By the way, this is what is done for the APS model, but for other reasons. It was found that the response matrix from elegant can differ from the difference orbit from an experiment because in the latter case we have significant orbit variation in sextupoles.
I guess the effect of corrector length should be important if there is some significant betatron phase advance along that steering element.
I've found a simple workaround: the effect of FSE in a bend can be replaced with two HKICKs at the beginning and at the end of the magnet. For a coasting beam (fixed_length=0) the resulting closed orbit will differ from the exact solution only inside the bend -- that will actually produce some small path length error and for a bunched beam in a small ring can be taken into account as well.
Here is the expression for the required HKICK values:
HKICK1 = HKICK2 = -(FSE/(R*sqrt(K)))*( 1-cos(L*sqrt(K)) )/sin(L*sqrt(K)),
where K = K1 + 1/R^2, R -- bending radius, L-- bend length, K1 -- quadrupole component.
- Attachments
- APS.tar.gz
- 1 KICK vs 2 KICK approximation for BEND.FSE in the APS
- (568.61 KiB) Downloaded 1044 times
