MOGA optimizer for rings
- Contact:
As many of you know, APS is using a Multi-Objective Genetic Algorithm (MOGA) optimizer to develop lattices for operations and the APS upgrade. Details of our approach are described in this document:
http://www.aps.anl.gov/Science/Publicat ... 418279.pdf
In addition to APS, we've applied this algorithm to NSLS-II, SPEAR, Diamond, and PEPX. For those who might want to try it, I've uploaded a set of examples and instructions. You can get it from our software downloads page at
http://www.aps.anl.gov/Accelerator_Syst ... shtml#MOGA
- Contact:
Re: MOGA optimizer for rings
By the way, I'd like to thank Lanfa Wang (SLAC) for being the first to try this and helping to iron out some confusing parts.
Hi Michael
I have tried to used MOGA optimizer to optimize beam emittace and DA.
I found some problem with the DA calculation process in "processJob" script which integrate the clipped area.
It give abnormal large area when the unclipped area is zero. Those with the large area have DA like this: I tried to solve this problem by adding a line in the script:
-redefine=column,Area1, Area 0 == ? 0 : Area1 $ " \
this seem to solve the problem. However is there a better way to this?
And I wonder why the calculation gives the wrong values in the first place?
Also I try to use the FMA and diffusion rate as the objective for DA optimization but there is a problem with some points
(close to horizontal and vertical axis) which the algorithm can not find the real frequency (is it FFT ?) (If I understand correctly from your
explanation in another post)
as you can see:
Is there a way to solve this?
Many thanks
Thapakron
as you can see:
Many thanks
Thapakron
- Contact:
Thapakron,
I wonder if you are using a very old version of elegant? The problem with getting very large area when the area is actually zero was solved several releases ago (I thought). If not, perhaps you can post the files for one of these cases.
The problem with FMA near the y=0 plane is due to cross-plane coupling. When the y value is very small, the motion coupled from the x plane can produce complex motion that doesn't have an unique, easily-identified frequency. The best thing to do is ignore the data for small y. You can change the input file to increase ymin in the &frequency_map command, or just filter the data after the fact.
Michael,
Thanks a lot for your help.
I use Elegant 24.0.1-1.x86_64.
Please find the attached aperture output.
Thanks,
Thapakron
Thanks,
Thapakron
- Attachments
- 002834.aper
- area0
- (1.84 KiB) Downloaded 3253 times
- Contact:
Thapakon,
Can you try the most recent version? You are two versions behind.
If it still shows the problem, I need you to send the *input* files to diagnose the issue.
Hi Michael
The Area obtained from Elegant is correct (zero when there is no aperture).
But during the clipped Area (Area1) calculation by the script "processJob", it gives
some large constant value for example ***
Area_check :0.000000000000000e+00 (from .aper)
Area1_check:1.005000000000000e+00 (after processing) ***
On the other hand, when the Area is non-zero the clipped area (Area1) can be calculated correctly:
Area_check :1.125074645767331e-04 (from .aper)
Area1_check:7.669601360507396e-05 (after processing) ***
you can see from attached script.
Thanks a lot
Thapakron
Thanks a lot
Thapakron
- Attachments
- processTest.tar.gz
- script and aperture files
- (2.17 KiB) Downloaded 3080 times
Hi Michael,
I met a problem when I try to use the geneticOptimizer.
I met a problem when I follow the steps in the GuideToUse to run demo.
The problem is :
bash: plotTwiss: command not found.
We are using the "Elegant 25.1.0" in Red Hat Enterprise Linux Workstation release 6.3.
Could you give me some suggestions on this problem?
Regards,
Haisheng Xu
The problem is :
Regards,
Haisheng Xu
- Contact:
Haisheng,
The script plotTwiss should be included in the distribution, but perhaps we missed it. I've attached it here. Just unzip and put in your search path.
- Attachments
- plotTwiss.gz
- (3.07 KiB) Downloaded 3128 times
Thank you, Michael!
We'll try to add this script into the search path.
Regards,
Haisheng Xu
Regards,
Haisheng Xu
