is it possible to simulate an alpha-magnet with a multi-slit scraper using, e.g, a set of RCOL elements placed between the two virtual halves of the alpha-magnet...
Thank you very much,
Alexei
Multi-slit collimator inside an alpha-magnet
Re: Multi-slit collimator inside an alpha-magnet
Alexei,
The best way to do this is using the SCRIPT element, which will allow putting an arbitrary filter between the halves of an alpha magnet:
An example that might help is attached.
a1: alph,xmax=0.09,part=1
filter: script,command="filterScript %i %o"
a2: alph,xmax=0.09,part=2
bl: line=(a1,filter,a2)
- slitArray.tar
- (10 KiB) Downloaded 801 times
