Multi-slit collimator inside an alpha-magnet
Post Reply
alexei_sav
Post by alexei_sav » 16 Jun 2015, 17:11
Dear Michael,
is it possible to simulate an alpha-magnet with a multi-slit scraper using, e.g, a set of RCOL elements placed between the two virtual halves of the alpha-magnet...
Thank you very much,
Alexei
Contact:
Re: Multi-slit collimator inside an alpha-magnet
Post by michael_borland » 17 Jun 2015, 08:21
Alexei,
The best way to do this is using the SCRIPT element, which will allow putting an arbitrary filter between the halves of an alpha magnet:
Code: Select all
a1: alph,xmax=0.09,part=1
filter: script,command="filterScript %i %o"
a2: alph,xmax=0.09,part=2
bl: line=(a1,filter,a2)
An example that might help is attached.
slitArray.tar
(10 KiB) Downloaded 801 times
Post Reply
