change_momentum_p0=1 in RFCA
Hwang, Ji-Gwang
Post by Hwang, Ji-Gwang » 07 Feb 2010, 00:07
Hello, Dear all.
Now, I using the element of RFCA.
I want to change momentum of the beam after passing element of RFCA.
So, I am set the "change_momentum_p0=1" comment in lattice file.
But It has error. The error message is "item is ambiguous -- specify more of the item name"
How to fixing this error? Could you give me some comment?
I attached the file. Please check.
Sincerely yours.
optimize.ele
run file
(3.19 KiB) Downloaded 1137 times
line.lte
lattice file
(677 Bytes) Downloaded 1150 times
Re: change_momentum_p0=1 in RFCA
Post by michael_borland » 07 Feb 2010, 00:36
Ji-Gwang,
There is a typo in your file. You have BODY_FOCUS_MODEL = SRS). The ")" is not correct.
See the attached file.
line.lte
(678 Bytes) Downloaded 1217 times
Hwang, Ji-Gwang
Post by Hwang, Ji-Gwang » 07 Feb 2010, 02:02
Dear Michael
Thank you for your reply. But Still don't change the value of energy after passing RFCA.
What's the problem?
Sincerely yours.
Hwang Ji-Gwang
Post by michael_borland » 07 Feb 2010, 12:24
Ji-Gwang,
Your definition of RFCA doesn't specify the a value for phase. Try PHASE=90 for on-crest acceleration.
Per the manual: "The phase convention is as follows, assuming a positive rf voltage: PHASE=90 is the crest for acceleration. PHASE=180 is the stable phase for a storage ring above transition without energy losses."
Hwang, Ji-Gwang
Post by Hwang, Ji-Gwang » 07 Feb 2010, 20:50
Thank you for your help. your answer is correct.
sincerely yours.
Hwang, Ji-Gwang
