Hello!
I discovered a good example of ramping up sextupoles for finding closed orbit and correcting it in presence of strong sextupoles and errors. Unfortunately, vary_element function does not support wildcards and type parameter which is somewhat an inconvenience.
Is it possible to add these features?
Wildcards and type parameter for vary_element
Skamarokha
Respectfully,
Mikhail A. Skamarokha.
Re: Wildcards and type parameter for vary_element
Mikhail,
I'll look into adding that. Meanwhile, you can use the link_elements feature to reduce the inconvenience.
Skamarokha
Thank you, good suggestion
Respectfully,
