Dependence of CSR energy loss on transverse beam size
Post Reply
Sergei
Post by Sergei » 18 Aug 2010, 14:30
Hello,
I was tracking beam through bunch compressor with chicane consisting of CSRCSBENDs and CSRDRIFTs and I noticed that energy lost by the beam depends on horizontal beam size. Is it the behavior one expects to see in ELEGANT? If so, could you please let me know how transverse beam size is taken into account in CSR calculus? I’ve been assuming that ELEGANT uses 1D CSR model (as described in Michael’s 2001 Phys. Rev. ST-AB paper) and thus results of CSR effect shall depend on longitudinal beam parameters only.
Thanks a lot!
Sergei
Contact:
Re: Dependence of CSR energy loss on transverse beam size
Post by michael_borland » 18 Aug 2010, 15:31
Sergei,
The only way I can think of that this might happen is through the dependence of path-length on x and x' . This could alter the longitudinal distribution in the dipole magnets and give the result you observe.
If you can post your input files, I can look at it more detail.
Sergei
Post by Sergei » 18 Aug 2010, 16:33
Thank you, Michael,
Here are the files. One of the ways to check that energy loss depends on horizontal beam size is to change horizontal emittance in .ele file. For instance, change in emittance from 4e-6 to 36e-6 drops energy loss at chicane exit (element CHICANE4) from 0.42MeV to 0.28MeV.
Thanks much,
Sergei
BC_Ich50_tripon.ele
(2.02 KiB) Downloaded 1138 times
BC_Ich50_tripon.lte
(2.82 KiB) Downloaded 1045 times
Contact:
Post by michael_borland » 18 Aug 2010, 17:15
Sergei,
I confirmed this effect, as shown in the second plot, where I plot the momentum offset vs the emittance (x and y emittances are the same).
I'm pretty sure this is a result of the variation of the bunch length in the chicane dipoles as the emittance is varied. In the other plot, I show bunch length for several different emittances. For lower emittance, the bunch length is shorter in the dipoles, which leads to a stronger CSR effect. This agrees with the observed variation in energy loss with emittance.
Bunch duration vs emittance in the chicane section.
Momentum offset vs emittance at the end of the system.
Sergei
Post by Sergei » 18 Aug 2010, 17:21
Michael,
Thank you very much! That explains everything.
Sergei
Post Reply
