Is this a Bug?
Post Reply
CCH
Is this a Bug?
Post by CCH » 01 Jul 2010, 04:36
I did a tracking of a simple lattice ,but the normalized emittance changed.Is this a bug? Can you have a look
CCH
Re: Is this a Bug?
Post by CCH » 01 Jul 2010, 04:37
These are the files
erl.lte
(599 Bytes) Downloaded 1197 times
erl.ele
(1.68 KiB) Downloaded 1089 times
Contact:
Re: Is this a Bug?
Post by michael_borland » 01 Jul 2010, 08:25
It's not a bug, but rather a result of the fact that you plotted the uncorrected emittance and have dispersion in the system. The uncorrected emittance is defined as
ex = sqrt{ <x^2> <xp^2> - <x*xp>^2 }
If there is dispersion (e.g., following a dipole magnet), then this quantity can grow.
If you plot the corrected emittance (ecx or ecnx), you get a different picture. For the corrected emittance, we make the transformation
x -> x - delta*etax
xp -> xp - delta*etaxp
prior to computing the emittance.
As you can see in the attached plot, ecnx is nearly constant. It isn't exactly constant because of chromatic aberrations from the quadrupoles.
Post Reply
