Hi Michael,
Is there a simple way to modify the code such that Elegant corrects the closed orbit using a set of selected trims and BPMs? For example, I'd like to simulate fast orbit correction using only the fast correctors, and maybe part of the BPMs. The misalignment error is already corrected; therefore, I can't disable the slow correctors because they define the golden orbit.
Regards,
Weiming
Orbit correction
Orbit correction
- Contact:
Re: Orbit correction
Weiming,
It shouldn't be necessary to modify the code. If you separate the slow steering and fast steering into two runs (or stages of the same run), you can use the STEERING parameter of the HKICK, VKICK, and HVKICK elements and the WEIGHT parameter of the HMON, VMON, and MONI elements to control which elements elegant uses in steering. The steering adjustments from the first stage will appear in the parameter file, which you can load for the second stage.
Let me know if that doesn't work out.
Michael,
Thanks a lot!
So if the steering knob is set to zero, the "correct" command will not use the corrector for orbit correction, but the "close_orbit" command still takes the kick into account. Is this understanding correct?
Regards,
Weiming
Thanks a lot!
Regards,
Weiming
- Contact:
Weiming,
Yes, that's right.
Yes, that's right.
Dear Michael,
I do not understand how the program defines "golden" orbit in order to simulate fast orbit correction.
I mean that fast orbit correction should correct orbit to the "golden" one, but not to the ideal orbit.
Do I need use &closed_orbit module in the second stage (fast steering)?
It seems to me that the program tries to perform correction to the ideal orbit in the second run.
Sincerely yours, Vyacheslav
- Contact:
Slava,
The "golden" orbit is defined the by the DX and DY values on the monitor elements. If you want the second stage of correction to respect the orbit established by the first stage, you'll need to map the closed orbit into DX and DY, then load with load_parameters.
This can be done using sddsprocess to read the closed orbit output from the first stage, creating a file for DX values and another for DY values.
I've attached an example that may help.
- Attachments
- goldenOrbit.zip
- (20.74 KiB) Downloaded 114 times
