LSRMDLTR reference phase
Post Reply
imartin
Post by imartin » 12 Mar 2010, 08:49
Hi,
I am trying to understand better the LASER_PHASE parameter for the LSRMDLTR element. I can use this parameter to shift the phase of the laser, but have not been able to work out how the zero-phase is defined. Also, how does this relate to the TIME_OFFSET parameter for the external time-dependent modulation of the laser beam?
Thanks,
Ian
Contact:
Re: LSRMDLTR reference phase
Post by michael_borland » 12 Mar 2010, 09:51
Ian,
The phase of the laser field is calculated as phi=k*(z-L/2) - omega*t + phi0, where L is the length of the undulator, t is the time coordinate of the particle, phi0 is the phase specified. Unfortunately, I didn't use (t-tc), so it a bit confusing to set phi0. I'd suggest using LASER_PHASE of omega*L/(2*c) + dphi, where dphi is the desired phase.
For the profile offset, the time coordinate used for the lookup table is t - tfid + tOffset, there tfid is the arrival time of the fiducial particle at z=L/2 and tOffset is the TIME_OFFSET parameter.
Hope this helps.
imartin
Post by imartin » 12 Mar 2010, 10:59
Michael,
So if I understand correctly, the phase of the laser is not necessarily fixed with respect to the time envelope? Is this the case? ie if I set the LASER_PHASE and TIME_OFFSET to particular values and then track a different bunch through the element, this could give a different phase wrt to the peak of the time envolope due to the different value for tfid?
thanks,
Ian
Contact:
Post by michael_borland » 12 Mar 2010, 12:57
Ian,
Yes, that's correct.
imartin
Post by imartin » 23 Apr 2010, 07:56
MIchael,
I have been trying to carry out jitter simulations using the LSRMDLTR element, fixing the phase of the laser with respect to the time envelope. To do this I was tracking 2 bunches, the first to act as the fiducial bunch and then apply errors to the linac for the second bunch. When I try this the time envelope remains constant between the two bunches, but the phase of the laser changes. Is there a way to fix the phase? I've attached the .ele and error files I've used as reference, and also a plot showing the longitudinal phase space for the two bunches at the end of the linac.
thanks again,
Ian
longitudinal phase space comparison
PVB.003.sdds
error definitions
(203.85 KiB) Downloaded 455 times
slicing_PVBI.003.ele
elegant input file
(1.34 KiB) Downloaded 461 times
Post Reply
