Study of TMCI
weijie
Re: Study of TMCI
Post by weijie » 02 Dec 2024, 02:47
Hello Michael
I have also encountered the error "
Program trace-back:
error: frequency values not equally spaced for real data (ZLONGIT)".
The impedance file is also attached below. The space between frequencies is 1e11 Hz.
Thank you for your help.
Weijie
rw.sdds
(560.21 KiB) Downloaded 1571 times
Contact:
Re: Study of TMCI
Post by michael_borland » 16 Dec 2024, 14:50
Weijie,
I don't get that error when using your file. However, I get another error:
Code: Select all
error: impedance spectrum has non-zero imaginary DC term (ZLONGIT)
This is a confusing message, but what it indicates is that you didn't supply f=0 data in your file. Elegant looks at the first row in the file and assumes that is the DC term, then complains that the imaginary part is nonzero (which is unphysical).
weijie
Re: Study of TMCI
Post by weijie » 17 Dec 2024, 02:49
Hi Micheal
I have solved the problems above. That works for me. Thank you!
Thank you again for your help.
Best Regards
Weijie
Post Reply
