Large Cx Amplitude in Beamline Model with ZTRANSVERSE
Post Reply
Olga Konstantinova
Post by Olga Konstantinova » 05 Apr 2024, 03:01
I'm trying to simulate the transverse y impedance using the ZTRANSVERSE command with BBR in a simple beamline model. The model includes elements like ILM, SREFFECTS, RFCA, and an impedance element (LST files attached). However, I'm encountering a large amplitude in the Cx value that I can't eliminate. The center position and angle have no offset and are zero, and the impedance is defined as the y-direction, so I think the question is rather why it vibrates so much in the x-direction?
v07_14_ele_z_rev7.lte.txt
(627 Bytes) Downloaded 2115 times
csr_v07_14_z_rev7.ele.txt
(1.86 KiB) Downloaded 2545 times
Contact:
Re: Large Cx Amplitude in Beamline Model with ZTRANSVERSE
Post by michael_borland » 19 Aug 2024, 11:42
I think the problem is just that you set X_DRIVE_EXPONENT=0. That means that the horizontal wake is a monopole wake, so that there is a kick in the x plane regardless of x position. If you want to turn off the horizontal wake, set XFACTOR=0
Post Reply
