Hello,
I am trying to use computeRBGGE, following the example in elegantExamples. However, when running this function the magnetic fields in the output file are huge (of order 10^10 or greater).
The magnetic field file used is attached, along with the script for generating the GGE (copied from the examples). It is not clear to me whether the issue is with my implementation of the script (i.e. optional arguments that should be given), or with the precision or range of the field file, or something else entirely.
Thank you in advance for your support,
Alex
Usage of computeRBGGE
- Attachments
- lgbend_example.tar.gz
- (1.93 MiB) Downloaded 2579 times
- Contact:
Re: Usage of computeRBGGE
Alex,
Something is not right in construction of the magnet field map file. For example, if I plot By(x=0,y=0,z) using
I get
Also, if try to plot By(x,y) as a function of z using
I get an error message
Code: Select all
$ sddsplot -col=z,By magmnew.sdds -filter=col,y,-1e-6,1e-6 -filter=col,x,-1e-6,1e-6 -graph=sym
Code: Select all
$ sddssort magmnew.sdds -pipe=out -col=z -col=x -col=y | sddsbreak -pipe=in magmnew-split.sdds -change=z
$ sddscontour -shade -xyz=x,y,By magmnew-split.sdds
Code: Select all
Error: x and y data does not appear to form a grid (nx=101, ny=7, rows=808)
Hi Michael, thank you very much for your reply. As you mentioned, there was an issue with the field file. I originally had only 1/4 of the magnet and had to generate the other parts by reflecting the fields across the Y and Z axes, and I made a mistake. Now it looks more regular.
The issue with the contours is still present, however. Is it required to have the same number of grid points? There are not many samples in the Y direction from the magnet file.
Alex
Alex
