QUAD.HKICK and element division
Post Reply
petrenko
Contact:
Post by petrenko » 29 Jan 2010, 13:46
Michael,
There is rather annoying bug in QUAD element with HKICK or VKICK steering used. If you divide the quadrupole using "divide_elements" command then the steering kick value is simply copied to each slice. This results in many-fold increase in overall steering.
Thanks.
Alexey.
Contact:
Re: QUAD.HKICK and element division
Post by michael_borland » 29 Jan 2010, 14:27
Alexey,
Sorry about the bug. It will be fixed in the next release. Meanwhile, if you want a workaround, try
&divide_elements name=*, type=QUAD, divisions=10 &end
&run_setup .. &end
&alter_elements name=*, type=QUAD, item=HKICK, value=0.1, multiplicative=1 &end
&alter_elements name=*, type=QUAD, item=VKICK, value=0.1, multiplicative=1 &end
If you build from source, you can try substituting the attached file for track_data.c
track_data.c
(222.04 KiB) Downloaded 1129 times
petrenko
Contact:
Post by petrenko » 29 Jan 2010, 14:51
Thank you, Michael. I really appreciate your help!
Contact:
Post by michael_borland » 20 Apr 2010, 13:42
This was fixed in release 23.1.0
Post Reply
