sddsanalyzebeam Twiss parameters
Post Reply
Adam_Dixon
Post by Adam_Dixon » 18 Oct 2022, 09:02
Hello,
I am looking into how slice Twiss parameters evolve through a bunch compressor. I do this by slicing the beam and assigning each particle to a slice, then I use sddsanalyzebeam on each slice to get the slice beta and alpha along the bunch compressor. Typically I do this with a 2,000,000 macro-particles and have used 20-600 longitudinal slices. I've noticed the slice Twiss parameters were larger than the whole beam Twiss parameters from twiss_output. I assigned the particles to a single slice to check whether the sddsanalyzebeam Twiss match that of twiss_output, in case there problem was the number of slices, but I still found the Twiss parameters from sddsanalyzebeam were much larger than from twiss_output. I find that more slices I use the larger the slice parameters get. The corrected geometric emittance and sigma beam size from sddsanalyzebeam match the sigma output file.
I have attached plots of beta, ecx and Sx along the bunch compressor using *twiss and *sigma output files, and using the equivalent single 'slice' beta, ecx and Sx from sddsanalyzebeam at each watch file. Also attached the *ele and *lte and initial bunch.
Do you understand why the beta from *twiss output and sddsanalyzebeam are different here?
max4.ele
(1.96 KiB) Downloaded 2650 times
MAXIV_BC2.lte
(18.7 KiB) Downloaded 2612 times
Adam_Dixon
Re: sddsanalyzebeam Twiss parameters
Post by Adam_Dixon » 18 Oct 2022, 09:04
Here are the figures comparing twiss and sigma output compared to those from sddsanalyzebeam. It also won't let me attached the initial bunch distribution.
Thanks,
Adam
Contact:
Post by michael_borland » 20 Oct 2022, 12:34
Adam,
Are you using the -correctedOnly option on sddsanalyzebeam, to get the true beta functions (with suppression of dispersive effects)? Either that, or look at the betacx, betacy, etc, values.
Adam_Dixon
Post by Adam_Dixon » 21 Oct 2022, 04:17
Hi Michael,
I'm not using the -correctedOnly option, but in the above beta function plot betax and betacx are the uncorrected and corrected values from sddsanalyzebeam. Where both are larger than the twiss_output (betax.twi) values.
Adam
Contact:
Post by michael_borland » 21 Oct 2022, 10:25
Adam,
Can you provide the file input/BC2.W-INIT and any other input files I might need to run this?
Adam_Dixon
Post by Adam_Dixon » 21 Oct 2022, 11:48
I have attached BC2.W-INIT. The script I used to slice the beam and track the slices, is similar to what you provided here - viewtopic.php?t=1201.
Adam
BC2.zip
(97.24 MiB) Downloaded 2631 times
Contact:
Post by michael_borland » 27 Oct 2022, 16:48
Adam,
The discrepancy appears to be due to strong chromatic effects. If I convert the entire lattice to use matrix-based tracking (SBEN, QUAD, SEXT), then set default_order=1 in run_setup, the beta functions agree between max4.twi and max4.sig. However, if I set default_order=2, the discrepancy appears. If I set the energy spread to zero, there's agreement even with default_order=2.
The twiss parameter computation can't include such effects, whereas determination of twiss parameters from particle distributions necessarily has them (if the tracking is so configured).
Adam_Dixon
Post by Adam_Dixon » 02 Nov 2022, 05:47
Thanks for the help Michael!
Post Reply
