Hi,
I'm trying to run haissinski with the attached twiss file:
> haissinski tps79h2wake.twi tps79h2wake.hai \
-model=Zn=0.36 \
-bunchCurrent=0.667 \
-outputLastStepOnly \
-RF=Voltage=3.5e6,harmonic=864 \
-superPeriods=24 \
-energy=3 \
-integrationParameters=deltaTime=1.0e-12,points=1.0e-6,startTime=1.0e11,iterations=1000
> sddsprintout tps79h2wake.hai -param=Convergence
and always get this output:
Printout for SDDS file tps79h2wake.hai
Convergence = Solution did not converge
I'm not sure about integration parameters I've used, they may be not optimal. Could you please advise on suitable integration parameters.
Thank you,
Andriy
haissinski: Solution did not converge
arusanov
- Location: National Synchrotron Radiation Research Center
- Attachments
- tps79h2wake.twi
- Elegant twiss file
- (171.06 KiB) Downloaded 468 times
- Contact:
Re: haissinski: Solution did not converge
Andriy,
Sorry that those parameters are not very easy to set. I always have to look them up myself. Here's my suggested command:
haissinski tps79h2wake.twi tps79h2wake.hai -model=Zn=0.36 -bunchCurrent=0.667e-3 \
-outputLastStepOnly -RF=Voltage=3.5e6,harmonic=864 -energy=3 \
-integration=deltaTime=1e-13,points=4000,fraction=0.01,iterations=1000,tolerance=1e-4
Note that I removed the superperiods=24 argument because your .twi file contains the whole lattice. Also, the bunch current should be given in Amps, whereas I think you assumed mA. I choose the deltaTime parameter as roughly bunchLength/c/100. Otherwise I always use the values above, so I should probably update the defaults in the program.
By the way, the GUI script elegantRingAnalysis will run haissinski and some other programs.
arusanov
Thank you very much for the quick reply.
Now the solution converges. I will certainly try elegentRingAnalysis soon.
arusanov
If I try to specify wake function, haissinski produces "Segmentation fault".
haissinski tps79h2wake.twi tps79h2wake.hai -wakeFunction="wake.sdds",tColumn="t",wColumn="Wneg" -bunchCurrent=0.667e-3 -outputLastStepOnly -RF=Voltage=3.5e6,harmonic=864 -energy=3 -integration=deltaTime=1e-13,points=4000,fraction=0.01,iterations=1000,tolerance=1e-4
Segmentation fault
I've traced the source code and have found that this error comes from the function call:
scanItemList(&dummyFlags, scanned.list+1, &scanned.n_items, 0,
"tColumn", SDDS_STRING, tCol, 1, 0,
"wColumn", SDDS_STRING, wCol, 1, 0,
NULL)
Is there something wrong in my input? Thank you.
tps79h2wake.twi has been posted above.
Segmentation fault
NULL)
- Attachments
- wake.sdds
- Wake function
- (31.32 KiB) Downloaded 530 times
- Contact:
Andriy,
Thanks for reporting this bug.
As far as I can tell, the developer of haissinski never tested the wake feature, since it had a few argument parsing bugs. I corrected these and did some basic tests. It appears to give valid results, but you may wish to devise your own tests.
The corrected code is attached.
- Attachments
- haissinski.c
- (37.64 KiB) Downloaded 505 times
arusanov
Thank you very much, haissinski works fine now.
