floor_coordinates: vary_ele vs alter_ele vs error_ele
Post Reply
frank_stulle
Post by frank_stulle » 13 Nov 2009, 11:10
Am I right with the assumption that floor coordinates are calculated from the values in the lattice file, i.e. before vary_element and error_element are applied? Only the alter_elements command is applied before floor coordinates are calculated?
Regards
Frank
Contact:
Re: floor_coordinates: vary_ele vs alter_ele vs error_ele
Post by michael_borland » 13 Nov 2009, 14:20
Frank,
Yes, that's right. Also, floor coordinates are updated, but not written out, during optimization.
It would be a good thing to remove this limitation. I'll add it to my list. Meanwhile, you can use alter_elements and a script to get the same result. Please see the attached file for an example.
varyFloor.tar
(10 KiB) Downloaded 463 times
Post Reply
