I am trying to &correct the beam trajectory of a beam that I import from an earlier simulation. The manual seems to say that I can simply load the particles using &sdds_beam and set use_actual_beam = 1 inside &correct. However, when I do this the &correct command is considerably less verbose and the files %s.traj and %s.cor contain only the header. I have attached a minimal functioning example of the problem. When &bunched_beam is used, &correct appears to work. When &sdds_beam is used, &correct does not appear to work.
I am running elegant 2020.3.0.
Using &correct with &sdds_beam
- Attachments
- correct_test.tar.gz
- (2.84 MiB) Downloaded 2592 times
- Contact:
Re: Using &correct with &sdds_beam
If you are using Pelegant, this won't work. It only works with elegant at present. I suggest sampling the particle distribution to reduce the number of particles so the runtime isn't too long.
