I am trying to use MRFDF element to implement multipole fields to my RF kick. But with a kick inside a ring, I would like to turn on/off this kick (MRFDF) on a particular pass only. Like RFDF where the switch is available, is there switch in MRFDF?
Thanks
MRFDF switch available?
- Contact:
Re: MRFDF switch available?
I think you are referring to the START_PASS and END_PASS parameters on RFDF. Unfortunately, we don't have that feature on MRFDF. However, you should be able to use the &modulate_elements command to get the same effect.
For example, suppose your revolution period is 4e-6 s and you want to turn the MRFDF on for Pass>=1000 and off again for Pass>1010:
Be sure to use a precise value for the revolution period.
Code: Select all
&rpn_expression
expression = "4e-6 sto T0"
&end
&modulate_elements
name = *, type = MRFDF, item = FACTOR, differential = 0, multiplicative = 1,
expression = "T0 / int sto Pass Pass 1000 < Pass 1010 > || ? 0 : 1 $ "
&end
