Hi,
I am looking at generating beams inside Elegant for test purposes. I want them to have a chirp, and I also want to be able to set specific curvatures, e.g. from the RF voltage, for a beam going into a compressor. I really can't figure out how to do this, and to me, it looks like it is not possible. I can't get my own script to produce proper transverse phase spaces, so it would be nice to be able to do it directly in Elegant.
Any help is appreciated
Best regards
Jonas
Longitudinal phase-space curvature
- Contact:
Re: Longitudinal phase-space curvature
Jonas,
My suggestion is to use elegant's bunched_beam command to generate the transverse phase space you want with some nominal longitudinal phase space, then modify the longitudinal coordinates to suit your needs. There are a few options here
- Use a thin RFCA element to manipulate the longitudinal coordinates. You can adjust the voltage, phase, and frequency to affect chirp and curvature.
- Use a SCRIPT element to manipulate or replace the longitudinal coordinates.
- Generate the longitudinal coordinates separately and replace those elegant generates using sddsconvert (to delete t, p) and sddsxref (to import new values).
