acceleration in a ring over multiple passes
Post Reply
VMorozov
Post by VMorozov » 11 Aug 2016, 08:57
Hello,
I am trying to accelerate a beam in a ring. I am using multiple passes through a lattice containing an RFCA element with CHANGE_P0=1 but what I find is that the reference momentum is updated only on the first pass. On the subsequent passes the reference momentum remains constant and I believe there is no scaling of the magnetic field strengths. Here is a simple illustration.
A simple lattice file consisting of a single FODO cell (test.lte):
DSXT: DRIF, L=0.05
DQAFE: DRIF, L=0.05
DBXAFE: DRIF, L=0.14
BXAF: CSBEND, L=8, ANGLE=0.07333499518, TILT=0, &
E1=0.03666749759, E2=0.03666749759, K1=0.0 ,N_KICKS=20
DAF01: DRIF, L=0.96
DAF02: DRIF, L=0.51
SXT02: KSEXT, L=0.5, K2=0.0, TILT=0, N_KICKS=10
QAF02: KQUAD, L=0.8, K1=-0.157938024375, TILT=0, N_KICKS=20
SXT01: KSEXT, L=0.5, K2=0.0, TILT=0, N_KICKS=10
QAF01: KQUAD, L=0.8, K1=0.158759981625, TILT=0, N_KICKS=20
RFCSIM: RFCA, L=0, VOLT=30.0E3, PHASE=210, FREQ=13059280.07573, &
CHANGE_P0=1, CHANGE_T=0
MON: DRIF, L=0.15
BXYC: DRIF, L=0.5
W1:WATCH,mode="coordinates",filename="w1.sdds"
FODO: LINE=(&
W1,DSXT,SXT01,DSXT,DQAFE,QAF01,DQAFE,MON,DAF01,DBXAFE,BXAF,DBXAFE,DAF02,RFCSIM, &
DSXT,SXT02,DSXT,DQAFE,QAF02,DQAFE,MON,DAF01,DBXAFE,BXAF,DBXAFE,DAF02)
USE,FODO
RETURN
A command file (test.ele):
&change_particle
name = proton
&end
&run_setup
lattice = test.lte,
use_beamline = FODO,
rootname = test,
default_order = 1,
p_central_mev = 8.0E3
&end
&run_control
n_steps = 2,
n_passes_fiducial = 1,
first_is_fiducial = 1,
restrict_fiducialization = 1,
reset_rf_for_each_step = 0,
n_passes = 10000
&end
&bunched_beam
&end
&track
&end
&stop
Here is what I get when I do: sddsplot w1.sdds -par=Pass,pCentral
or sddsplot w1.sdds -col=p,x
The offset grows with momentum, which means that the fields are not being scaled.
Can you help please? I tried many different options. It works okay in a storage mode but whenever I try to accelerate over multiple passes I do not seem to be able to update the reference momentum after the first pass.
I am using the latest version of Elegant (elegant 30.1.0, Aug 8 2016).
Thank you very much in advance!
Vasiliy
Contact:
Re: acceleration in a ring over multiple passes
Post by michael_borland » 11 Aug 2016, 09:09
Vasiliy,
There are some special steps you need to take to simulate ramping a ring. This includes using the RAMPP (ramp momentum) and RAMPRF elements. See the attached files and let me know if you have further questions.
boosterRamp.zip
(40.3 KiB) Downloaded 930 times
VMorozov
Post by VMorozov » 11 Aug 2016, 11:24
Thank you very much, Michael! This really helps.
Post Reply
