Advice On Calculating Second Order Correlations?
Post Reply
Zamank
Post by Zamank » 20 Apr 2015, 16:18
Greetings,
I am interested in calculating second order correlations between the energy deviation and longitudinal position (namely......<s*delta*delta>), I looked throughout the Elegant manual and outputs but there does not seem to be any data on this. Does any one know o an tricks or shortcuts to find this info?
I am thinking of using sdds to manually calculate the correlations, but thought some one would have a better way?
Thanks in advance!
Contact:
Re: Advice On Calculating Second Order Correlations?
Post by michael_borland » 20 Apr 2015, 17:22
There's nothing ready-made to do this, but sddsprocess should make it relatively painless. Use -define to compute quantities such as s*delta*delta, then -process=sdd,ave,%sAve etc to compute the statistical quantities.
Post Reply
