Hello,
Was reading Michael's PRST-AB on modeling microbunch instability and see lots of figures showing the current distribution (current vs time). Is this column generated in a particular output file or did you compute this using sdds tools?
Thanks,
chris
Current Distribution
- Contact:
Re: Current Distribution
Chris,
I think you are referring to the output from CSRCSBEND. Use the OUTPUT_FILE parameter to specify a filename, and you should see what you are looking for.
Michael,
Okay, thanks - it's the linear density. I see it now.
As I was reading through your paper I'm able to follow until you describe the numerous steps you take to obtain the gain curve (p. 5). In particular, I am not familiar with NAFF. Any suggestions/help/examples you could provide to understand better what is involved with this analysis?
Thanks,
chris
Thanks,
chris
I should've looked at the SDDS Toolkit manual first! I see a sddsnaff now. I don't suppose you have an example for all the steps you discuss in your paper (e.g. make histogram, remove ends, polynomial fit, naff, etc...)?
- Contact:
Chris,
I don't have the link for the original paper, but this paper describes the algorithm (see page 5) and gives references
cdsweb.cern.ch/record/301630/files/p183.pdf
The attached script is the one I used to perform the analysis. It expects a set of histogram files (produced with the HISTOGRAM element) with the run parameters encoded in the file rootname. See the comments for explanations.
- Attachments
- processHistograms.gz
- (1.36 KiB) Downloaded 498 times
headdoggy64
Hello,
Just wondering if this procedure is valid.
1)
2) to get FFT of current
3) to obtain FFT of modulations in energy
Also, why does the current after sddsfft still have the units of Amp?
Thanks,
Alex.
1)
Code: Select all
elegant2genesis bunch.out test.out -slices=200 -totalCharge=20e-12 2)
Code: Select all
sddsfft test.out test.tmp -columns=s,current 3)
Code: Select all
sddsfft test.out test2.tmp -columns=s,gamma Also, why does the current after sddsfft still have the units of Amp?
Thanks,
Alex.
- Contact:
Alex,
What you are doing is valid, at least mathematically, since the spacing of the s points is uniform.
I'm not sure why it is surprising that the FFT of I(s) has units of Amps. Unlike a continuous Fourier transform, the discrete Fourier transform is just a sum of the samples times some exponentials. There's no change of units.
