Location insensitive of the MALIGN element
Hi Michael,
I use MALIGN element to search for the maximum stable offsets. However, no matter where I put it, it displaces the coordinates as if it is at the beginning of the beamline. In other words, I always get the same dynamic aperture even if I move that element along the beamline.
Weiming
Weiming
- Contact:
Re: Location insensitive of the MALIGN element
Weiming,
That is very strange. Can you post some files that show the effect, or send them to me by email?
Thanks.
Thanks.
Was this topic resolved ?
I have a question along the same line. I have a layout where a quadrupole is rotated in the horizontal plane by 10 deg. I simulate
it by entering the beam at an angle of opposite sign with MALIGN. I was expecting to have to restore the trajectory by a MALIGN of opposite sign at the end. It does'nt appear to be so. The MALIGN only seems to apply to the next element, as follows (note my non-active original lines).
Mis1R: MALIGN,DXP=0.1745329252
!Mis2R: MALIGN,DXP=-0.1745329252
yqdrnorot: quad,L="lyquad", K1="YQc largeQcon * kpeak *",FFRINGE ="lyquad lypeak - lyquad /" ,FRINGE_TYPE="INSET", ORDER=3
!yqdr: line=(Mis1R,yqdrnorot,Mis2R)
yqdr: line=(Mis1R,yqdrnorot)
Thanks, cheers, Max
Thanks, cheers, Max
Max, I still see that problem mentioned above. However, yours is different. It won't completely restore the orbit if you use two MALIGN element as described in your message. You would get a displacement at the end due to the misalignment angle. You will need to correct that as following:
MA1: dxp=theta
MA2: dxp=-theta,dx = -theta*L
where L is the distance between MA1 and MA2. But this would be a good test of the original problem.
Weiming
MA1: dxp=theta
Weiming
- Contact:
Here are some files that involve several malign elements. If you run
% elegant run.ele
% sddsprintout -column=ElementName -column=s -column=Cx* run.cen
ElementName s Cx Cxp
m m
_BEG_ 0.000000e+00 0.000000e+00 0.000000e+00
MAL1 0.000000e+00 0.000000e+00 -1.000000e-03
D1 1.000000e+00 -1.000000e-03 -1.000000e-03
MAL2 1.000000e+00 -1.000000e-03 1.000000e-03
D1 2.000000e+00 0.000000e+00 1.000000e-03
MAL1 2.000000e+00 0.000000e+00 0.000000e+00
As you can see, the trajectory is kicked by each MALIGN element.
I think this shows that this much-maligned (pun intended) feature of elegant is working correctly.
% elegant run.ele
m m
- Attachments
- run.ele
- (152 Bytes) Downloaded 1138 times
- lattice.lte
- (93 Bytes) Downloaded 1153 times
Thank you Michael and Weimin,
I did as you suggested and it works.
Another question: is there an easy way to transfer closed orbit data (rms or maximum value) into the .FIN file so that
I can use "optimize" (I only have one corrector for a special application) instead of the global closed orbit correction instruction ?
Thanks, cheers, Max
Thanks, cheers, Max
- Contact:
Max,
I think you want to fit the trajectory at an interior point using optimization. To do this, you need to insert a MARK element at the fit location, with FITPOINT=1, as in
M1: MARK,FITPOINT=1
BL: line=(...,M1,...)
In your optimization terms, you then use M1#1.Cx for the x centroid, etc. If you have multiple instances of the same MARK element in the beamline, use M1#1, M1#2, etc., Look here for more details.
M1: MARK,FITPOINT=1
I checked my original problem. It occurred while I use the command find_aperture. In the lte file I defined two beam lines:
ring1 = (MA1,beamline1, beamline2)
ring2 = (beamline1,MA1,beamline2)
and I searched for dynamic aperture for both beam-lines and I was expecting to get different dynamic apertures since the beta functions are different at MA1 in two cases. However,
find_aperture always outputs dynamic aperture at the beginning. I checked the manual, apparently the default setting is to find aperture at the beginning of the beam-line. It never asks for a misalignment element.
Therefore this was a wrong assumption of mine, not a bug of elegant.
Regards,
Weiming
Regards,
Weiming
Michael,
many thanks for the useful information. Actually, I meant to optimize the closed orbit rather than the trajectory.
What I meant was: I know that .FIN (where the parameters reside that are used by "optimize") carries the trajectory data. Is there an easy way to
carry the closed orbit also ?
Cheers, Max
Cheers, Max
- Contact:
Max,
Sorry I misunderstood your question. It is possible to optimize the closed orbit. You need to do three things:
1. Set CO_FITPOINT=1 on all HMON, VMON, and MONI elements that you'll want to use in the optimization. If you want to use them all, just add this command before the optimization_setup command:
&alter_elements name=*, type=*MON*, item=CO_FITPOINT, value=1 &end
2. Give a closed orbit command before the optimization_setup command, e.g.,
&closed_orbit
start_from_centroid = 0
&end
3. Make optimization_terms involving the monitors, e.g.,
&optimization_term
term = "HMON#1.xco sqr" &end
&optimization_term
term = "VMON#1.yco sqr" &end
This is illustrated in the attached files.
&closed_orbit
&end
&optimization_term
&optimization_term
- Attachments
- par10h.lte
- (2.45 KiB) Downloaded 1209 times
- run.ele
- (1.56 KiB) Downloaded 1174 times
