Radia kickmap
Post Reply
wguo
Radia kickmap
Post by wguo » 24 Jul 2008, 09:01
Radia kickmap is really simple in terms of scripting. I implemented the method into Elegant by using a SCRIPT element. In the lte file, the script element is defined as
DWSCRIPT: SCRIPT,COMMAND="./DWkickmap -input %i -output %o -Bmax %np0 -kickmapFile %sp0",&
verbosity=1,NP0=1.0, SP0="W90v5_pole80mm_finemesh_7m-x.sdds", KEEP_FILES=1,use_csh=0
Then I inserted this element to the lattice at the center of the straight section.
Tracking through the kick map is realized by the script DWkickmap, which is attached to this message.
DWkickmap needs four parameters, the input file, output file, Bmax, and the kickmap file. Bmax (0~1) is a scaling factor for the map. It can be interpreted as the relative field strength while the gap of the ID varies. The kickmap file is an sdds file. Another script, kickmap2sdds is also attached, which converts a typical text kickmap file (see the attachment) into sdds format.
Unfortunately at this stage the SCRIPT command works only for tracking. It is treated as a drift space when lattice functions are calculated. It would be nice if it will be upgraded into a normal element.
Weiming
kickmap2sdds.txt
remove the txt extension and change the mode to executable.
(2.4 KiB) Downloaded 730 times
W90v5_pole80mm_finemesh_7m.txt
(71.49 KiB) Downloaded 752 times
W90v5_pole80mm_7m-x.sdds
(42.21 KiB) Downloaded 721 times
wguo
attachement files
Post by wguo » 24 Jul 2008, 09:18
The maximum allowed number of attachment is 3, so I attached them here.
Weiming
kickmap2sdds.txt
These two files are tck/sdds command files. Remove the txt file extension and change the mode to executable.
(2.4 KiB) Downloaded 737 times
DWkickmap.txt
(2.96 KiB) Downloaded 717 times
Contact:
Re: Radia kickmap
Post by michael_borland » 24 Jul 2008, 10:31
Weiming,
Thanks for posting this. I'm planning to include a built-in kick-map element in elegant in the next release.
Also, it should be possible to have elegant compute the matrix for the SCRIPT element using tracking, as it does with CWIGGLER.
wguo
Re: Radia kickmap
Post by wguo » 29 Sep 2008, 10:24
Michael,
Could you add synchron radiation loss to ukickmap as what you did to Wiggler and Cwiggler? I guess you have similar subroutines.
Weiming
Contact:
Re: Radia kickmap
Post by michael_borland » 29 Sep 2008, 13:25
Weiming,
It's a good suggestion. I should be able to get this into the next release.
Post Reply
