Number of Output Pages
Post Reply
JoelFrederico
Post by JoelFrederico » 01 Jun 2011, 19:11
Is there a way to find out how many pages are in a particle output file programmatically, in particular that would be fast over very large files with hundreds of pages?
For instance, a series of bash commands that would print out how many pages are in a file?
Contact:
Re: Number of Output Pages
Post by michael_borland » 01 Jun 2011, 19:24
Joel,
You can use "sdds2stream -npages=bare <filename>" . This program also has the ability to report the number of rows (-rows=bare).
Contact:
Post by michael_borland » 01 Jun 2011, 19:25
Joel,
Another tip: if the file is very large, it might be faster to look at another, smaller file that is generated by the same elegant run and will have the same number of pages.
JoelFrederico
Post by JoelFrederico » 02 Jun 2011, 13:51
Michael,
Thanks. This method takes about 5 minutes on a 6 GB file, so we'll keep looking for alternate methods. I was hoping to avoid the secondary file method, but that seems like the only solution now. Unless maybe there's a character sequence in the binary format that represents a new page that we could grep (or something similar)?
Joel
litos
Post by litos » 02 Jun 2011, 17:50
Hi Joel and Michael,
I think I have come up with a faster solution for finding the page count of an sdds file. I use sddscollapse on the original input file, then define a parameter in the new file that is simply the number of rows in the new file, which should be equal to the number of pages in the original input file. This can then be printed with sddsprintout.
For example:
Code: Select all
sddscollapse $1 -pipe=out -noWarning |\
    sddsprocess -pipe -noWarnings \
    "-define=parameter,pagecount,n_rows,type=long" |\
    sddsprintout -pipe=in -par=pagecount
I found this code can give the page count on a 6 GB file in about 10 seconds (the same file Joel was using for benchmarking, I believe).
-Mike Litos
Post Reply
