Transient beam loading with passive Harmonic cavity
Post Reply
Tyagi
Post by Tyagi » 20 Apr 2022, 05:32
Dear All,
I want to see the effect of different filling patterns on the bunch length in presence of passive harmonic cavity for my case. Just to start with, can any one help me and share some example files.
regards
D K Tyagi
Contact:
Re: Transient beam loading with passive Harmonic cavity
Post by michael_borland » 23 May 2022, 12:40
Please see the attached files, which show how to simulate 4 trains of 12 bunches with main and harmonic rf cavity beamloading.
Some sample output
Tyagi
Post by Tyagi » 09 Jun 2022, 05:50
Sir,
Can you please share some input files where bunch lengthening with different filling pattern are calculated.
regards
Contact:
Post by michael_borland » 01 Jul 2022, 16:16
Please try the attached files.
There's a README file that gives some guidance. The script generateBunchTrain is used to make the fill pattern.
transientBeamLoading.zip
(2.76 MiB) Downloaded 1032 times
Pradeep
Post by Pradeep » 15 Aug 2023, 00:31
Dear Dr. Borland,
I use elegant example file "touschekWithHHCFromTracking" for simulation of Touschek beam lifetime with a parasitic 4th-harmonic RF cavity and got results. In this example "generate bunch train" command is not used. Can you please send example file in which bunch train command is used for simulation of bunch length and Touschek lifetime simultaneously in bunch trains?
Thanks,
Pradeep Kumar
Contact:
Post by michael_borland » 28 Aug 2023, 12:36
Pradeep,
I can't find that example. Can you post it?
Pradeep
Post by Pradeep » 28 Aug 2023, 22:58
Dear Dr. Borland,
Please find attached example file for simulation of Touschek lifetime in presence of passive harmonic RF cavity which I received from you earlier. I want to study Touschek lifetime with uniform and non uniform RF buckets fill, due to transient beam loading, bunch length will be different in bunch train along the beam path. In non uniform fill due to different bunch length, bunch-by-bunch Touschek lifetime will be different. Please help me how to simulate bunch-by-bunch bunch length and Touschek lifetime using generate bunch train command.
Thanks and regards,
Pradeep
touschekWithHHCFromTracking.tar.gz
(1.97 MiB) Downloaded 883 times
Contact:
Post by michael_borland » 19 Sep 2023, 15:00
Pradeep,
Please see the attached file for an example.
touschekWithHHCFromTracking-nonuniformFill.tar.gz
(1.69 MiB) Downloaded 848 times
Post Reply
