GSAS/EXPGUI Alumina tutorial (part 4)
Changing the Background Function
GSAS offers approximately 10 different background functions (not all are
implemented in EXPGUI). For each of these functions, the number of terms
to be used is adjustable. The more terms the more complex the shape that
can be fit.
Each of these background functions
has different shapes, and in theory, each function will have advantages
under different circumstances.
However, this author
finds that the Shifted Chebyschev (type #1) is preferable to the
others for the vast majority of Rietveld refinements and almost never uses
any other function.
When a histogram is first added in GSAS, the background function is set to the
Cosine Fourier series option (type #2) with two adjustable terms.
In this section of the tutorial, we change the background function and the
number of terms.
To change the background function, press the "Edit Background" button on the
histogram panel.
Note the "Refine background" check box has been selected -- this means that
the background parameters will be refined (optimized) when GENLES is run.
The damping parameter to the immediate left is set to 0 -- this means that
the full computed shift will be applied. In cases where a refinement has
trouble reaching a minimum, it may be advantageous to increase damping
(a setting of 1 implies 90% of the computed shift will be applied and
a damping setting of 9 yields a shift of 10%.)
Every refinable parameter in
GSAS has a refinement flag (either for the group, as in this case,
or for each individual parameter) and a damping parameter. The appearance
of the check box is slightly different in windows: a "x" appears in the
box when the parameter is selected.
After the "Edit Background" button is pressed,
The "Edit Background" window opens, as is shown to the right.
In this window both the function type and the
number of terms can be changed.
Clicking on the "Function type" menu offers a choice of function types,
as is shown to the right. Choose function type #1, the Shifted
Chebyschev function.
Note that the "Fit Background Graphically" invokes the EXPGUI
BKGEDIT program, which is used to fit a background function
directly to user-supplied points. This is a very useful initial way to
fit the background in difficult cases.
Also in the "Edit Background" window, press on the "Number of terms" button
and change this number to 6, as is shown to the right. Note that with
the Chebyschev polynomial arbitrary (including zero) starting values for the
background terms is acceptable.
After the "Set" button is pressed, the changes are then seen on the histogram
panel, as shown below.
Note that by default, the refine background flag is set, allowing these
parameters to be optimized.
Previous:
Specifying Powder Diffraction Data
Next step:
Initial Fitting: Refine Scale Factor and Background
