GSAS/EXPGUI Alumina tutorial (part 2)
Adding a phase
When a GSAS experiment file is first created, a fair amount of information
must be supplied before the refinement of parameters can be started. At a
minimum, a crystallographic phase must be defined, a set of diffraction
data must be loaded and a starting values for experimental parameters
must be defined. Fortunately, this can be a fairly simple operation
with GSAS and EXPGUI.
This page shows how a crystallographic phase is
specified in EXPGUI. For a mixture, this step would be repeated for
each crystallographic phase. If an impurity is identified in a later
stage of the refinement, this step can be run at that point to define
this additional crystallographic phase. GSAS allows up to nine crystallographic
phases to be included in a model.
To enter information about a crystallographic phase, modify
crystallographic parameters, or select crystallographic parameters
to be optimized the "Phase" panel must be selected by clicking on the
"Phase" tab in the upper left of the EXPGUI window. The window then appears
as shown just below this text.
It should be noted that the Phase panel will have a slightly different
appearance after one or more phases have been entered,
(see below).
The next step is to press the "Add Phase" button in the upper left.
The "Add New Phase" window, shown immediately below, is then generated.
Information about the phase can be added directly into the boxes,
or phase information can be read from a file. For this exercise,
we will read unit cell parameters, the space group and atom parameters
from a CIF file. This means that we need to select the "Crystallographic
Information File (CIF)"
format from
the options by pressing the file format button
in the lower right-hand corner.
When the "Import Phase from" button is pressed, an "open file"
window is created (this window has a slightly different appearance,
but the same function in Windows). On this window, the file to be read is
selected, and then the "Read" button is pressed.
The CIF is then read and the unit cell information is included
in the appropriate entry boxes, as shown below.
If this input is acceptable, press "Continue".
One of the places where errors occur in the preparation of GSAS input
is in the entering of space group symbols. For this reason, after the
"Continue" button is pressed, a window such as the one below, is
created to help you confirm that the correct space group has been entered.
It is recommended that you read through this information to check that
this is correct. As an example of a possible error, if one entered the
corundum example in the rhombohedral setting,
rather than the hexagonal setting,
then the space group should be entered as "R -3 c R" (where the final R
indicates the rhombohedral setting). The listing of lattice centering vectors
is only appropriate for the hexagonal (centered) cell.
Since the symmetry information is correct in this example, press the "Continue"
button on the "check symmetry" window. At this point, since atom
coordinates were read from the CIF file, the "add new atoms" window is
opened and the atom coordinates are entered into the appropriate boxes,
as seen below. Press the "Add Atoms" button at the lower left to continue.
Note that if atoms were not being read in from a file,
it would now be necessary
to press the "Add New Atoms" button to input atoms to the phase.
In this case, there would be no atoms entered into the window.
After pressing the "Add Atoms" button, the two atoms are added to the
experiment and the phase panel appears, as below.
Previous:
Creating an Experiment File
Next step:
Add data file to the Experiment
