GSAS/EXPGUI Alumina tutorial (part 11)
Finishing Up
In the previous refinement steps we obtained quite good agreement
between the computed pattern and the observed diffraction data,
with a Chi2 value of 2. CW neutron data have very regular peaks
shapes and can often provide significantly better fits. Improving the fit
allows perhaps slightly better values for the derived parameters, but more
importantly offers smaller error estimates (standard uncertainties).
In this final step we will allow each atom to have independent Uiso
parameter, we will add more background terms,
and we will switch the profile function to use the
Finger-Cox-Jephcoat asymmetry parameter, which does a better job of modeling
low-angle asymmetry.
To delete the displacement factor constraint, go to the Constraints panel,
and select the Delete check button to the right of the constraint, as shown
below. Then press the "Delete" button below it, near the bottom of the window.
The program then prompts, as shown to the right, to confirm deleting the
constraint.
The constraint no longer appears in the panel, as shown below.
To increase the number of background terms, select the Histogram panel,
and press the "Edit Background" button,
as was done in part #4. The window to
the right is then created. Click on the
"Number of terms" pull-down menu and select 12 terms.
To change the profile function, go to the Profile panel and press the
"Change Type" button. This opens a window where the function can be selected
and where the starting value for each profile parameter can be set.
Set the function type to 3 and see how
the number of terms expands to what is seen below.
Note that the instrument parameter file usually contains default
values for the various profile terms. The values constitute the left-hand
columns of buttons. Where two terms are used the same way in
different profile functions, the previous value is shown in the right-hand
column.
The profile functions are described in detail in the
GSAS documentation.
For the CW neutron and x-ray functions, the functions can be
summarized as follows:
- Type 1: Simple Gaussian peak shapes, poor asymmetry correction;
appropriate for CW neutrons only.
- Type 2: Pseudo-Voight function, poor asymmetry correction; good for
refinements where low-angle peaks are not significant
- Type 3: Similar to type 2, except this includes the Finger-Cox-Jephcoat
asymmetry correction. Good even with significant low angle peaks.
- Type 4: Similar to type 3, except this includes the Stephens model for
anisotropic strain broadening (where different classes of reflections
have different widths).
As is shown below,
press on the "Current" button for GU, GV and GW, to change the starting
values for those parameters to what was obtained previously, rather than the
values in the instrument parameter file.
Again select GU, GV and GW for refinement in the Profile panel, as below.
With these extra parameters, the refinement converges with still better
values for the agreement factors, as seen below.
Since the diffractometer constants and profile terms have been changed,
POWPREF should be run again.
The Chi2 and Rwp improve even more when GENLES is run, indicating
that the previous run of POWPREF was needed.
The resulting fit is quite good. By turning on "Cumulative
Chi-squared" in the Options menu, the purple line diagonal line
is shown. This highlights the worst fit areas of the pattern in terms
of their impact on the weighted profile r-factor (Rwp) or in Chi2.
The Cumulative Chi-squared plot was first demonstrated by W. I. F. David
at the Accuracy in Powder Diffraction Meeting-III (2001) (See the
LIVEPLOT documentation for more information.
The line would
have a constant slope (slope=1), if all regions of the data are fit at the
statistically expected level. The areas where the Cumulative Chi-squared
has a much greater slope are regions that have poorer fits.
Previous:
Group Uiso parameters &
Refine coordinates and Overall Uiso.
