SMOOTHDIST6
jrowland
SMOOTHDIST6
Post by jrowland » 23 Apr 2009, 05:06
Hello
Is the SMOOTHDIST6 script from "Modeling of the microbunching instability, M.Borland, PRSTAB" available for use with Elegant?
Thanks
James
Re: SMOOTHDIST6
Post by michael_borland » 23 Apr 2009, 20:18
James,
It should be part of the installation. Try typing "smoothDist6s". If not, you can try install the attached script.
smoothDist6s.zip
(3.34 KiB) Downloaded 440 times
jrowland
Re: SMOOTHDIST6
Post by jrowland » 24 Apr 2009, 03:17
Thanks, it's in the elegantTools directory in elegant-21 (missed that one).
Re: SMOOTHDIST6
Post by michael_borland » 28 Apr 2009, 08:36
James,
Just a word on the use of smoothDist6: it is best used for determining the microbunching gain curve of the system. Because of the algorithm used, some of the detailed correlations among various phase space coordinates will get lost. If you just want to increase the number of particles without adding modulations, I suggest using another script, called doubleDist6. I don't think it is in the distributed source yet, so I've attached a copy.
doubleDist6.zip
(1.66 KiB) Downloaded 459 times
