Is there a way to optimize free parameters other than element parameters? For example, in the lte file
1.0 sto K1f1
2.0 sto K1f2
Q1: QUAD, L=0.2, K1=K1f1*0.8+K1f2*K1f2*0.02
Instead of using K1 of Q1 as optimization variables, I would like to vary K1f1 and K1f2. Is it possible to do so in Elegant?
Weiming
Opertimization other than element parameters
Re: Opertimization other than element parameters
Weiming,
Unfortunately, the answer is no at present. You can use the optimization_covariable command to optimize parameters of elements as functions of other parameters of elements, which may help if you restate the problem in terms of different variables.
