Hello i am trying correction simulation.
In elegant, a command "correct" can be used for the orbit correction. There are many options to limit the singular values(SV). For examples, "keep_largest_SVs" or "minimum_SV_ratio". What if I want to see the SVs directly, where can I find the values. Which output file? or which setting command? Please let me know that. I will be a pleasure to me. Thank you!
Gyeongsu
Orbit correction - Singular Value Decomposition
Re: Orbit correction - Singular Value Decomposition
Gyeongsu,
If you want to see the SVs directly, you need to use the program sddspseudoinverse together with the output files from the &correction_matrix_output command.
