sddsplot issue in macOS 10.14
I've upgraded my MacBook to the latest macOS 10.14, but I could no longer run sddsplot properly. For example, when I run "sddsplot -col=s,betax Basic.twi", I got an warning of "Warning: XmManager ClassInitialize: XmeTraitSet failed", followed by the following Error info:
Error: attempt to add non-widget child "DropSiteManager" to parent "mpl_motif" which supports only widgets
and no plot was shown in the mpl_motif environment.
However, I could still export the sddsplot results to a png file using "sddsplot -col=s,betax Basic.twi -device=png -output=s_betax.png".
I tried to recompile the SDDS (3.6.1) from source, and also downloaded the binary executables (darwin-x86_SDDS.tar.gz (February 22, 2018)), both attempts failed to solve this issue.
Does anyone know the cause of such an issue?
Thanks very much!
Zhe
Thanks very much!
Zhe
Re: sddsplot issue in macOS 10.14
I am currently running MacOS 10.11.6 and am scheduled to get upgraded to MacOS 10.12 this week. A far cry from 10.14 unfortunately. Perhaps the trick of getting sddsplot to work on 10.12 will work on 10.14. Try first running:
export DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace
Hi Soliday,
Thank you for your prompt reply!
I have set "export DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace" by default, and this worked for macOS 10.13 before I upgraded to macOS 10.14.
Anyway, I can still export the sddsplot results to png files, just a little bit inconvenient.
Zhe
Zhe
Hi Soliday,
Are there any updates regarding the solution of the sddsplot issue as I mentioned in this post, on macOS 10.14 or later versions?
Thanks!
Zhe
Thanks!
Zhe
I believe this workaround is no longer required. However I don't have access to my MacOS laptop till next Monday so I can't confirm this. I'll make a note to check when I get back.
I am running Mac OS 10.15.7, and I wound up getting elegant and SDDS to install by using homebrew to install motif:
brew install openmotif
Before I tried that, I did
brew install --cask xquartz
which helped with some errors but wasn't enough. I'm not sure if openmotif will include xquartz or if you will have to do both.
-Gregg
-Gregg
System: MacOS Mojave 10.14.6
Intel CPU
XQuartz 2.8.1
MacPorts 2.7.2
openmotif 2.3.8
Results from "otool -L mpl_motif" verify it is using the X11 libraries from /opt/X11/lib which is where XQuartz puts them and not /opt/local/lib which is where MacPorts has it's own versions.
Previously it required DYLD_LIBRARY_PATH to be set and point to /opt/X11/lib/flat_namespace. This doesn't appear to be required anymore. I also verified that I hadn't overwritten my /opt/X11/lib/libXt.6.dylib with /opt/X11/lib/flat_namespace/libXt.6.dylib. These should be different sizes.
System: MacOS Monterey 12.4
M1 CPU
XQuartz 2.8.1
MacPorts 2.7.2
openmotif 2.3.8
The results are the same on this system as well.
Intel CPU
XQuartz 2.8.1
MacPorts 2.7.2
openmotif 2.3.8
M1 CPU
XQuartz 2.8.1
MacPorts 2.7.2
openmotif 2.3.8
I spent some time recompiling SDDS on my Mac OS 10.15.6. Following Gregg's approach, I did
brew install --cask xquartz & then brew install openmotif
This installed XQuartz 2.8.1 and openmotif 2.3.8
After that, I had to modify epics/extensions/configure/os/CONFIG_SITE.darwin-x86.darwin-x86 changing MOTIF_LIB & MOTIF_INC to where homebrew installed openmotif.
then I had to resolve the issue that /usr/X11/include/X11/extensions/Print.h cannot be found by copying the file "Print.h" from another linux machine, and I had to modify /Users/duanz/Applications/elegant/elegant-2021.1.0/epics/extensions/src/SDDS/SDDSaps/sddsplots/motifDriver/Makefile by removing Xp from PROD_SYS_LIBS_Darwin. Both Print.h and Xp are no longer part of Xquartz 2.8.1. And I guess these are not used in sddsplot either.
After that I could compile SDDS from source succesfully.
Then I did otool -L mpl_motif, I got:
mpl_motif:
/usr/local/opt/openmotif/lib/libXm.4.dylib (compatibility version 5.0.0, current version 5.4.0)
/usr/local/opt/jpeg/lib/libjpeg.9.dylib (compatibility version 15.0.0, current version 15.0.0)
/opt/X11/lib/libXmu.6.dylib (compatibility version 9.0.0, current version 9.0.0)
/opt/X11/lib/libXt.6.dylib (compatibility version 7.0.0, current version 7.0.0)
/opt/X11/lib/libXft.2.dylib (compatibility version 6.0.0, current version 6.3.0)
/opt/X11/lib/libXext.6.dylib (compatibility version 11.0.0, current version 11.0.0)
/opt/X11/lib/libX11.6.dylib (compatibility version 11.0.0, current version 11.0.0)
/opt/X11/lib/libfontconfig.1.dylib (compatibility version 14.0.0, current version 14.0.0)
/usr/lib/libiconv.2.dylib (compatibility version 7.0.0, current version 7.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
/usr/local/opt/readline/lib/libreadline.8.dylib (compatibility version 8.0.0, current version 8.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1281.100.1)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 902.1.0)
However, when I do a simple test like sddsplot -col=s,betax parTwiss.twi, I got the following warnings and no plot was seen:
Warning: ... found while parsing '<BtnMotion>: ManagerGadgetButtonMotion()'
Warning: String to TranslationTable conversion encountered errors
Warning: translation table syntax error: Unknown event type : EnterWindow
Warning: ... found while parsing '<EnterWindow>: ManagerEnter()'
Any suggestions to solve this issue? Thanks!
Zhe
mpl_motif:
Zhe
Well my first suggestion would be to try to download and run the pre-compiled MacOS binaries for SDDS. I have taken care of ensuring to link to as many static libraries as possible to avoid the issues similar to what you are seeing.
As for Print.h, I have a copy that I think was installed with openmotif in /opt/local/include/Xm/Print.h
I have libXp in /opt/local/lib/libXp.a
I moved /opt/local/lib/libXp.dylib to /opt/local/lib/libXp.dylib.orig to avoid linking to the dynamic library. I have a bunch of other dynamic libraries in this directory I did the same thing to:
/opt/local/lib/libXm.dylib.orig
/opt/local/lib/libgd.dylib.orig
/opt/local/lib/libhdf5.dylib.orig
/opt/local/lib/libiconv.dylib.orig
/opt/local/lib/libjpeg.dylib.orig
/opt/local/lib/liblzma.dylib.orig
/opt/local/lib/libncurses.dylib.orig
/opt/local/lib/libpng.dylib.orig
/opt/local/lib/libtiff.dylib.orig
/opt/local/lib/libxml2.a.orig
/opt/local/lib/libxml2.dylib.orig
/opt/local/lib/libz.dylib.orig
/opt/local/lib/libzstd.dylib.orig
I make sure to link with the libraries in /opt/local/lib and not /opt/X11/lib by setting:
MOTIF_LIB=/opt/local/lib
MOTIF_INC=/opt/local/include
X11_LIB=/opt/local/lib
X11_INC=/opt/local/include
% otool -L mpl_motif
mpl_motif:
/opt/X11/lib/libXau.6.dylib (compatibility version 7.0.0, current version 7.0.0)
/opt/X11/lib/libpng16.16.dylib (compatibility version 55.0.0, current version 55.0.0)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1311.100.3)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 1300.23.0)
% otool -L sddsplot
sddsplot:
mpl_motif:
% otool -L sddsplot
sddsplot:
