Neeraj
Post
by Neeraj » 04 Jul 2018, 10:05
When I run,
./view3dGeometry -rootname 0.47383208735214516.flr
I get the error:
invalid command name "APSStandardSetup"
while executing
"APSStandardSetup"
(file "./view3dGeometry" line 8)
I know that APSStandardSetup is found in .../x86_64/elegant/34.2.0/share/tcltk/oagtcltk/
while OAG_TOP_DIR is .../x86_64/elegant/34.2.0/local
can someone tell me where/how should I make the change to solve this issue?
Thanks
-Neeraj
Post
by soliday » 05 Jul 2018, 09:26
.../x86_64/elegant/34.2.0/share/tcltk/oagtcltk/ and .../x86_64/elegant/34.2.0/local are not standard locations.
For your setup, I would create a symbolic link from .../x86_64/elegant/34.2.0/local/oag/apps/lib/linux-x86_64 to .../x86_64/elegant/34.2.0/share/tcltk/oagtcltk
Normally the RPM installation would create a symbolic link from /usr/local/oag/apps/lib/linux-x86_64 to /usr/shar/tcltk/oagtcltk
