Hi,all!
When I tried to replace the IDs from CWIGGLER to UKICKMAP,which I got from the example: cwiggler+kickmap.
However I found that U0 calculating by UKICKMAP is less than using CWIGGLER,and I also tried element GFWIGGLER,the result is similar to the
UKICKMAP.
Is this a normal result?Or I have to make some changes in producing input_file of ukickmap?
Thanks!
Shichang
Different U0 utilizing CWIGGLER/GFWIGGLER/UKICKMAP?
Re: Different U0 utilizing CWIGGLER/GFWIGGLER/UKICKMAP?
Shichang,
If you could provide files that show the problem, that would help.
Here is my lattice file and the .ele file.
The compressed files are the kickmap.sdds for the IDs,described by CWIGGLER are added in the lattice file.
Thanks for your timely respond!
Shichang
Shichang
- ukickmap.rar
- (240.35 KiB) Downloaded 638 times
- lattice_FO.lte
- (53.59 KiB) Downloaded 635 times
- injection.ele
- (1.57 KiB) Downloaded 640 times
Shichang,
I think it was a matter of not setting the parameters to the equivalent values. See the attached files. I get very good agreement.
After unzipping the file, change to the 2017-11-09 directory, copy in the kickmaps, and then type "runScript" to execute the test.
- 2017-11-09.zip
- (10.25 KiB) Downloaded 633 times
