How to scan the position of the quadrupole to measure the emittance
QinJohn
Post by QinJohn » 20 Oct 2017, 08:15
Hi All,
I'm a new to the elegant and I want to simulate the quadrupole scan method to measure the emittance. I have found an example in the ElegantExamples, in that example, the scan parameters are strength of the quadrupoles. Now I want to scan the quadrupoles' position, which can also lead to the change of the transfer matrix. When I change the parameter to the position, the results showed as follows:
Vertical emittance couldn't be determined
Horizontal emittance couldn't be determined
The attachment is my input file .Any one can help me to solve this question? Thank you !
one_quad.zip
(1.23 KiB) Downloaded 6228 times
Re: How to scan the position of the quadrupole to measure the emittance
Post by michael_borland » 23 Oct 2017, 09:59
John,
The problem seems to be that this method is very senstive to errors and to the fact that the beam size only goes through a minimum in one plane. I was able to improve matters slightly by using two stronger quadrupoles, see attached. Perhaps this will give a clue.
2017-10-23.zip
(51.54 KiB) Downloaded 6608 times
