vary several elements independently
Ikpfelix
Post by Ikpfelix » 15 Oct 2017, 07:20
I used vary_element for a few investigations. Now I want to vary several elements independently.
If I use
&vary_element name=MAL item=DP index_limit=11 initial=-0.01 final=0.01 &end
&vary_element name=MAL2 item=DX index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL3 item=DY index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL4 item=DXP index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL5 item=DYP index_limit=11 initial=-0.005 final=0.005 &end
I will get just 11 results. But I need all results of an independent variation, so in total all 11^5= 161051 possible combinations.
Is it possible to vary the elements in elegant independently or to use a general for-loop?
I tried it by using index_number, but every time I use a number not equal to zero elegant will not run:
&vary_element name=MAL1 item=DP index_number=0 index_limit=11 initial=-0.01 final=0.01 &end
&vary_element name=MAL2 item=DX index_number=1 index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL3 item=DY index_number=2 index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL4 item=DXP index_number=3 index_limit=11 initial=-0.005 final=0.005 &end
&vary_element name=MAL5 item=DYP index_number=4 index_limit=11 initial=-0.005 final=0.005 &end
Probably I am using index_number wrong.
I attached my files.
Thank you in advance
Felix
vary_files.zip
(1.84 KiB) Downloaded 376 times
Re: vary several elements independently
Post by michael_borland » 23 Oct 2017, 08:55
Felix,
Sorry for the delayed reply; I was away from work for a while.
All you need to do is change
&run_control n_indices=1 &end
to
&run_control n_indices=5 &end
Ikpfelix
Post by Ikpfelix » 23 Oct 2017, 10:25
somehow I did not notice that command. After changing it that way, everything works fine and as expected.
Thank you!
Felix
