SIGSEGVProgram trace-back
libov
Post by libov » 06 Sep 2017, 07:54
Dear Michael et al.,
I have a problem running elegant on Mac OS - never had any problems with same input files on linux.
The output is the following:
flashbkr4:Lattice libov$ elegant FLASHForward.ele
Running elegant at Wed Sep  6 14:47:46 2017
This is elegant 33.1.1, Jul 25 2017, by M. Borland, J. Calvey,M. Carla', N. Carmignani, M. Ehrlichman, L. Emery, W. Guo, R. Lindberg, V. Sajaev, R. Soliday, Y.-P. Sun, C.-X. Wang, Y. Wang, Y. Wu, and A. Xiao.
Thanks for using elegant.  Please cite the following reference in your publications:
  M. Borland, "elegant: A Flexible SDDS-Compliant Code for Accelerator Simulation,"
  Advanced Photon Source LS-287, September 2000.
If you use a modified version, please indicate this in all publications.
Link date: Jul 25 2017 10:14:54, SVN revision: 24422M
statistics:    ET:     00:00:00 CP:    0.00 BIO:0 DIO:0 PF:0 MEM:0
&global_settings
    inhibit_fsync = 0,
    echo_namelists = 0,
    mpi_randomization_mode = 3,
    exact_normalized_emittance = 1,
    SR_gaussian_limit = 3.000000000000000e+00,
    inhibit_seed_permutation = 0,
    log_file = {NULL},
    error_log_file = {NULL},
Seeding random number generators
computed value for D1FL2EXTR.DY is 0.000000000000000e+00
computed value for D1FL2EXTR.N_KICKS is 200
computed value for D1FL2EXTR.BINS is 200
computed value for D1FL2EXTR.ISR is 1
computed value for D1FL2EXTR.CSR is 1
computed value for D1FL2EXTR.OUTPUT_INTERVAL is 10
computed value for D1FL2EXTR.INTEGRATION_ORDER is 2
Terminated by SIGSEGVProgram trace-back:
It appears to happen with the dipoles, after coming to 'computed value for D1FL2EXTR.INTEGRATION_ORDER is 2' (for the case of D1FL2EXTR dipole)
Attached are the .ele and .lte files.
Thanks in advance for any advise!
Cheers
Slava
FLASHForward.lte
(40.33 KiB) Downloaded 573 times
FLASHForward.ele
(2.89 KiB) Downloaded 587 times
Re: SIGSEGVProgram trace-back
Post by michael_borland » 06 Sep 2017, 08:05
Slava,
I'm not able to reproduce the crash. Please add echo_lattice=1 to your run_setup command, then run again. This might provide an additional clue about the source of the problem, which appears to be in the lattice definition.
Post by soliday » 06 Sep 2017, 09:35
I see this problem on MacOS too. I am looking into it now.
Post by soliday » 06 Sep 2017, 16:07
I found the problem. I'll try to get an updated release out soon. In the mean time you can workaround the problem by changing the CSRCSBEN definitions so that ISR=1 and CSR=1 instead of ISR="with_ISR" and CSR="with_CSR". These are incorrectly being stored internally as long values instead of short values when you set them this way and results in this crash.
Post by soliday » 07 Sep 2017, 11:46
There is a new minor release now 33.1.2 posted to our software page. I updated the MacOS and Windows links to this new version.
libov
Post by libov » 07 Sep 2017, 23:43
The 33.1.2 release indeed solves the problem, thank you so much!
Slava
