I have a problem wiht my installation of scripts, such as km2sdds and others. This is an issue I will postpone, but just to let you know, the error I receive whan I call km2sdds is:
/cygdrive/c/Program Files (x86)/APS/Elegant x64/km2sdds: line 3: exec: oagtclsh: not found
However, in order to bypass this problem we tried to make our own undulator kick map, and beleive we did it identically to what km2sdd does. But, of course, it is not the case, since Elegant provides the followig error:
Error:
Unable to scan data--scanning or allocation error (SDDS_ScanData2)
Unable to read page--scanning error (SDDS_ReadAsciiPage)
I am attachning the files needed for running the two - apparently - identical kick maps.
Could you figure out what is different in the two kick maps?
Many thanks,
Simone
p.s.: in the .lte file, please search the IDVC_S8.1 element, for choosing either one or the other kick map.
Undulator kick map
simone.dimitri
Undulator kick map
- lattice.lte
- (68.1 KiB) Downloaded 861 times
- elettra_run0.ele
- (8.76 KiB) Downloaded 856 times
simone.dimitri
Re: Undulator kick map
I try to upload the kick map files again here.
S.
S.
- EU4.8_g19_pc_w48.zip
- (35.29 KiB) Downloaded 862 times
Simone,
I don't see a problem when I run elegant with either of the kickmaps you sent. In both cases, the first sequence (correcting the tune and chromaticity) and second sequence (momentum-dependent tune) run without a problem. I didn't try the other sequences, but suspect they'd be fine also.
At this point, I'm not sure what to recommend other than ensuring that you are using the latest version.
simone.dimitri
Well, I updated Elegant very recently, this is the version:
This is elegant 33.0.3, Mar 9 2017
I assume you run Elegant with the kickmap "EU4.8_g19_pc_w48.ukm" first, and "EU4.8_cir_gmin_test2.dat" then.
No idea....thank you anyway.
Simone,
Yes, I used each kickmap in turn and found no problems. Sometimes ASCII files generated on linux (windows) don't work on windows (linux), but I don't think that's the case here, since I don't see the characteristic funny end-of-line sequences.
