cygwin and oagtclsh error
OZGUR
Post by OZGUR » 21 Mar 2017, 08:49
I am trying to run "boosterramp" sample file which I also attached. It did not work on windows and I tried to run it with cygwin; and to be sure that cygwin and elegant works well, I tested it with twis calcularion and having plot, it works. so I am sure that cygwin and elegant is there and working well.
hovewer, when I start to run boosterramp file, I had a problem as I explained below;
I am doing what it writes in "notebook" document which is also attached;
- I write "elegant BYBL0.ele" to the command line ant it gives a twi file as an output.
- Hovewer, when I write "computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25" to command line, it gives an error and writes; "there is no oagtclsh".
I would appreciate if you could help me to figure it out.
boosterRamp (1).zip
(40.55 KiB) Downloaded 754 times
Re: cygwin and oagtclsh error
Post by soliday » 21 Mar 2017, 09:03
There is file installed with OAGTclTk called "Windows Instructions.txt" that explains what you need to do to get this to work. Try running:
tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25
If that doesn't work, try running:
c:/Tcl/bin/tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25
OZGUR
Post by OZGUR » 22 Mar 2017, 06:18
Hi Soliday, thank you for your effort but it did not work unfortunately.
When I write "tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25" to command line, it says;
no such variable
(read trace on "env(HOST_ARCH)")
invoked from within
"linsert $auto_path 0 /usr/local/oag/apps/lib/$env(HOST_ARCH)"
invoked from within
"set auto_path [linsert $auto_path 0 /usr/local/oag/apps/lib/$env(HOST_ARCH)]"
(file "computeRfRamp" line 5)
and when I write "c:/Tcl/bin/tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25", it says;
can't read "env(HOST_ARCH)": no such variable
while executing
invoked from within
In the meantime, I kept my effort to sort it out in another way;
- I tried to run it on cygwin as you suggested, I run Build-OAP-RPMs file and I have chosen "Yes" the first 4 selection between the download choices and "no" for the rest. At the end it gaves an error like;
Building SDDS RPM package. This may take a minute.
grep: /etc/passwd: No such file or directory
while executing
"exec ./rpmdev-setuptree"
("eval" body line 1)
invoked from within
"eval exec $sudo ./rpmdev-setuptree"
invoked from within
"if {$Build(SDDS)} {
puts "Building SDDS RPM package. This may take a minute."
eval exec $sudo wget -q http://www.aps.anl.gov/asd/oag/down...
(file "Build-AOP-RPMs.tcl" line 1108)
Do you help me how I can figure it out?
özgür
Post by soliday » 22 Mar 2017, 09:32
It sounds to me like you don't have OAG_Tcl-Tk installed on your computer. When you install this, it sets the HOST_ARCH variable and installs the needed files to run our scripts.
You will need ActiveTcl from:
http://downloads.activestate.com/Active ... readed.exe
Visual C++ 2013 Redistributable for Visual Studio 2013 from:
http://www.microsoft.com/en-us/download ... x?id=40784
OAG_Tcl-Tk from:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... Tk-x64.msi
The Build-AOP-RPMs script is only for linux and won't work on Windows.
