Dynamic aperture scan in x direction with a y offset
gwei
Post by gwei » 24 Jan 2017, 16:37
Hello, Michael, and other experts,
Usually we make dynamic aperture line survey as shown in follow figure.
line survey of dynamic aperture
And we can use like follow words to get the dynamic aperture for the line (X= n*sigma_x, Y=n*sigma_y), (X= -n*sigma_x, Y=n*sigma_y)
and (X= 0*sigma_x, Y=n*sigma_y).
&find_aperture
output = "%s.aper",
mode = n-lines,
n_lines = 41,
xmin = -0.001,
xmax = 0.001,
ymin = 0
ymax = 0.0005,
nx = 21,
ny = 11,
n_splits = 5,
desired_resolution = 0.00001,
verbosity = 1
But for the line (X= n*sigma_x, Y=1*sigma_y), I don't know how to make the dynamic aperture scan.
And when I make a scan with the line (X= n*sigma_x, Y=0*sigma_y), I can only get a result of NO 3 of follow figures which is not enough.
Thank you.
Guohui
Re: Dynamic aperture scan in x direction with a y offset
Post by michael_borland » 25 Jan 2017, 10:19
Guohui,
If I understand correctly, you want to set the initial y coordinate to a fixed value and scan the x coordinate to find the aperture. You can do this by simply creating a line of particles in phase space, e.g.,
&bunched_beam
	n_particles_per_bunch = 100,
	bunch = %s.bun,
	! 20mm horizontal size
	beta_x = 2e300,
	emit_x = 2e-304,
	! Zero vertical size
	beta_y = 1,
	emit_y = 0,
	! 1mm vertical offset
	centroid[2] = 1e-3
	! Distribution is a line in x-x' and y-y' phase space
	distribution_type[0] = 2*"line"
In addition, in the &run_setup command, you should request the acceptance output:
&run_setup
acceptance = %s.acc
The .acc file will contain the initial coordinates of all particles that survive tracking, which is the aperture in this case.
gwei
Post by gwei » 25 Jan 2017, 10:39
gwei
Post by gwei » 25 Jan 2017, 10:42
michael_borland wrote:Guohui,
&bunched_beam
	bunch = %s.bun,
	beta_x = 2e300,
	emit_x = 2e-304,
	beta_y = 1,
	emit_y = 0,
	centroid[2] = 1e-3
Thank you, Michael
And what's the meaning of ' centroid[2] = 1e-3 ' ? a y offset=0.001 m ?
In your definition of centroid, it is
double centroid[6] = {0.0, 0.0, 0.0, 0.0, 0.0, 0.0};
And I guess {0.0, 0.0, 0.0, 0.0, 0.0, 0.0} is values in (x, x’, y, y’, t, p)
Is it right?
Best wishes
Guohui
Post by michael_borland » 25 Jan 2017, 13:11
Guohui,
Is it right?
Yes, that's all correct, except centroid[4] and centroid[5], which are in units of meters and fractional momentum deviation, respectively.
gwei
Post by gwei » 25 Jan 2017, 13:59
Is it right?
So centroid[0] means x, centroid[1] means x', centroid[2] means y, centroid[3] means y', centroid[4] means t, centroid[5] means p.
if we want a centroid offset of x = 0.001 m and y = 0.001 m ,
we should write : centroid[0, 2] ={1e-3, 1e-3}. Is it right?
Post by michael_borland » 25 Jan 2017, 17:10
Guohui,
That's not quite right. centroid[4] is distance traveled, not time, while centroid[5] is (p-<p>)/<p>, not p itself. The syntax for changing several centroids is
centroid[0] = 1e-3
centroid[2] = 1e-3,
or
centroid[0] = 1e-3, 0, 1e-3
gwei
Post by gwei » 26 Jan 2017, 09:25
centroid[0] = 1e-3
centroid[2] = 1e-3,
or
Thank you very much! Michael
Guohui
