problem with CSBEND
ccwang
problem with CSBEND
Post by ccwang » 15 Jan 2009, 06:29
Recently, I met a problem with CSBEND. When I set the bending angle "ANGLE=0.0", it seems elegant can't calculate the betatron tune. Does anyone have comment on this? Thanks.
Chinchi
Re: problem with CSBEND
Post by michael_borland » 15 Jan 2009, 09:43
Chinchi,
Perhaps your lattice is unstable without the focusing from the bending magnet. I tried an example with a four-dipole chicane and was able to vary the angle from a nonzero value to zero without a problem, but this will be lattice-specific. My example files are attached.
chicane.lte
(226 Bytes) Downloaded 502 times
run.ele
(543 Bytes) Downloaded 491 times
ccwang
Post by ccwang » 15 Jan 2009, 20:27
Thanks a lot! Actually, I am using CSBEND as a combined quadrupole and sextuple.
QF1: CSBEND, L=0.15, ANGLE=0.0, K1=1.126772404841, &
K2=2.575468751638, FINT=0.0
Is it possible due to including quadrupole and sextupole components?
Best wishes,
Chinchi
ccwang
Post by ccwang » 15 Jan 2009, 20:55
I have one more question. When I set FINT=0.0 for my CSBEND, the parameters in the twiss file is not change. It seems strange. Is there any related parameters I should deal with also?
Thanks again.
Chinchi
Post by michael_borland » 16 Jan 2009, 09:21
Chinchi,
Actually, having K1 or K2 non-zero will cause a problem when the ANGLE is set to zero. If ANGLE=0, elegant treats the element like a drift space. This is a bug that I'll try to fix in the next release. Meanwhile, you can use the KQUSE element (combined quad/sext) or set angle to a very small, non-zero value.
FINT won't have any effect unless you set HGAP to a non-zero value.
