amplification fators
simone.dimitri
Post by simone.dimitri » 24 Oct 2016, 05:08
Hello everybody,
I would like to calculate amplifications factors in the Elettra2.0 ring, but I receive the error message:
"Terminated by SIGSEGVProgram trace-back:"
Clearly I am doing something wrong, but I could not figure out what. My files are in attachment.
Thank you in advance for help,
Simone
elettra0.new
lattice file
(3.15 KiB) Downloaded 1241 times
elettra_run1a.ele
command file
(2.31 KiB) Downloaded 1151 times
Re: amplification fators
Post by michael_borland » 24 Oct 2016, 08:18
Simone,
Unfortunately, this is a bug that slipped past the regression tester. I wasn't able to find a full workaround. However, you can get the uncorrected amplification factors using the attached file elettra_run1b.ele
Also, I fixed the bug and ran the simulation. Results attached.
2016-10-24.zip
(1.34 MiB) Downloaded 1165 times
simone.dimitri
Post by simone.dimitri » 24 Oct 2016, 09:17
Thank you Michael. It runs. Fine. Best,
S.
Aamna_Khan
Twiss parameters
Post by Aamna_Khan » 22 Nov 2016, 04:17
Hello everbody,
How should I fix Terminated by SIGSEGV problem while computing twiss parameters.
Earlier there was get_para_name() error. Its fixed up by changing the editor and beamline.
Thank you in advance.
Aamna
elegant.tar.gz
(2 KiB) Downloaded 1159 times
Post by michael_borland » 29 Nov 2016, 18:06
Aamna,
As you may have figured out, the problem was in the lattice file, which lacked continuation characters and separators in the beamline definition. See attached.
Int.lte
(6.08 KiB) Downloaded 1234 times
