Just build Pelegant (elegant.29.1.0.tar.gz) with SDDS.3.4.tar.gz and mpich 3.2
I build the SDDS using MPI=1 and Pelegant with the makePelegant script.
I checked that the serial elegant works, that my mpich installation works.
After the build is done, attempting to execute Pelegant:
mpiexec -n 4 /work/casa/oag/apps/bin/linux-x86_64/Pelegant ARC1.ele
yields:
table structure size is inconsistent
Error:
passed size is not equal to expected size for SDDS_DATASET structure
Passed size is 2608, library size is 2600
Is there some build option I need to enable or something to set?
structure size inconsistent
Re: structure size inconsistent
Yves,
You need to rebuild the SDDS libraries, both the serial and parallel versions.
