MATLAB sddsload not working with error log file
Alea88
Post by Alea88 » 08 Feb 2016, 10:03
Hello everyone,
I am using the sddsload function for MatLab and it works perfectly for all the sdds files produced by elegant but not with the ".erl" files produced with &error_control error_log=%s.erl &end.
When I issue the command
val=sddsload('test.erl')
I get the following error
Error using sddsload (line 30)
invalid parameter value at line #82 (readAsciiData)
It appears not to be able to parse the "ParameterError" column: I say this as I did
sddsconvert test.erl -delete=col,ParameterError
And then everything works fine.
I am using MATLAB 2015 and SDDSver 2.8
Is this a bug or I am doing something wrong?
Thanks in advance for your support,
Giovanna
Re: MATLAB sddsload not working with error log file
Post by soliday » 08 Feb 2016, 11:13
Can you send me an example of an .erl file that is causing this problem?
soliday@aps.anl.gov
Thanks.
Alea88
Post by Alea88 » 08 Feb 2016, 11:18
I actualy tried with more than one .erl file, such as the one in the elegant Examples folder:
elegantExample/outboardTrajCorr2/run2.erl
Giovanna
run2.erl
(10.53 KiB) Downloaded 713 times
Post by soliday » 08 Feb 2016, 11:57
It is actually complaining about the extra empty row at the end of the file. The Java code is incorrectly giving an error when it doesn't find a new page after the space. You can temporarily workaround the problem by using "sddsconvert run2.erl run2.erl -nowarn". This will rewrite the SDDS file with the number of rows of column data instead of not setting the number or rows like elegant is doing. I'll look into fixing the underlying problem though.
Alea88
Post by Alea88 » 08 Feb 2016, 12:01
Great,
Thanks for the fast and detailed answer
Giovanna
Post by soliday » 10 Feb 2016, 12:49
I updated SDDS Java for all our supported platforms. Installing the new version should fix this problem with Matlab.
