LEUTL Compression Question
Zamank
Post by Zamank » 24 Sep 2015, 12:18
I am investigating the CSR effect in the LEUTL beamline (attached are the *.lte and *.ele files). My first step is to compress the bunch as much as possible in the bunch compressor to exacerbate CSR. I am having trouble doing this and I am only able to get down to ~300um (Yine has told me she was able to simulate 30um compression).
Just wondering if I am doing something wrong here. Also, I realize there are no CSRCSBENDs in the *.lte file. I was planning to add those in after I investigated compression factors of the chicane.
I noted any changes I made to the deck with "!CHANGED".
Thank you!
scan.sdds
(860 Bytes) Downloaded 664 times
lattice.lte
(28.16 KiB) Downloaded 683 times
example.ele
(2.37 KiB) Downloaded 643 times
Zamank
Re: LEUTL Compression Question
Post by Zamank » 28 Sep 2015, 14:58
Any thoughts?
Post by michael_borland » 28 Sep 2015, 17:04
Sorry, I'm on travel and have a very slow connection. I'll try to get back to you in the next few days.
Post by michael_borland » 30 Sep 2015, 02:31
I was able to get ~200 um using the optimizer. It's best to keep the total beam energy fixed. See attached.
optimize.ele
(2.54 KiB) Downloaded 672 times
