optimization_term bug
Post by michael_borland » 06 Aug 2015, 16:46
The weight parameter of the &optimization_term command is ignored. This will be fixed in the next release. Those building from source can use the attached file, which has the patch.
A work-around is to add the weight to the expression, e.g., instead of
&optimization_term
	term = "betax sqr", weight=10
use
&optimization_term
	term = "betax sqr 10 *"
optimize.c
(113.99 KiB) Downloaded 884 times
