I am wondering if there exists a maximum available number of WATCH points used in a beamline. If so, is it possible to resolve this issue anyway? Attached is a simple drift with WATCH points added. When the number of WATCH points is increased to 249, there is an error message showing below:
Error:
Unable to open file test-249.w1 for writing (SDDS_InitializeOutput)
Thanks for help!
Cheng-Ying
ps. I am using 27.1.0 version.
maximum available number of WATCH points?
- WATCH249.zip
- (1.64 KiB) Downloaded 417 times
Re: maximum available number of WATCH points?
OSX has a default limit of 256 open files at one time. You can change that by first running:
ulimit -n 1024
ulimit -u 1024
After setting this, I was able to run elegant on your input files without any problems.
You can put these two commands in your .bash_profile to make the setting persistant.
ulimit -n 1024
ulimit -u 1024
It works! Thanks, Robert!
